ECM upgrade
Old Feb 26, 2011 | 12:36 AM
Hunter0075's Avatar
Car: 91camaro Rally, work in progress
Engine: 5.7 350. 400hp 400ftlb torq
Transmission: turbo 350
Axle/Gears: stock rs rear, 3.23.
ECM upgrade
Just found out I have to change my engine into A TPI. I know I have to installed a ECM out of a Z28. Is it best to get one from a junkard? Will it be wise to get a ECM and reprogram, Or get a new one. I have a 390 horse eng. high performance stuff in. have a cam which requires me to have 3000 rpm stall converter. Can the aftermarket programers capiable of doing that. thanks
Old Mar 2, 2011 | 09:20 AM
Ronny's Avatar
Re: ECM upgrade
Why do you need to switch to TPI?
Old Mar 2, 2011 | 09:51 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: ECM upgrade
You have a 390 HP TPI engine? If it was carbed and you put a TPI on it, that will change... HP down, torque up (with some nice TPI parts )
Anyway... the ecm's in the junkyard are programmed to specific fuel injectors, gear rations, etc...
Go here...
http://www.dynamicefi.com/
Rbob is member here too, it' his shop...
He has a nice setup that updates the stock ECM and you can program, etc...
I'm saving my pennies
Rafael
Old Mar 2, 2011 | 09:56 AM
Ronny's Avatar
Re: ECM upgrade
I was gonna suggest a single plane(vic jr or pro products) port EFI with EBL....
TPI cant handle that HP IMO.
seiplentz
Aug 19, 2019 06:02 PM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Billy Decker
Sep 4, 2015 03:46 PM
