HELP!!! new to tuning
Old Mar 6, 2011 | 10:03 AM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
i recently relpaced my o2 sensor and put a autometer fuel/air ratio gauge in. i have a mid to high level cam in and i noticed i am lean through most of the rpms. i adjusted the tps to richen it up but the idle gets erratic with it in drive it tends to surge and on the gauge it looks like the ecm is leaning the car out to much then it trys to fix it by dumping fuel making the rpms jump 100-200 at idle then it slowly trys to lean it back out. what should i do to fix this?
Old Mar 6, 2011 | 10:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: HELP!!! new to tuning
Changing the TPS won't change the fueling. But will wreck havoc on the idle. Reset the TPS to 0.54 volts and leave it. If you also played with the idle stop screw then do a full idle set up. The tech articles found from the home page has a link to the procedure.
IIRC, it is called "setting minimum air" or similar.
Since you changed the cam, de-screened the MAF maybe? The calibration needs to be tuned for the changes. This is done in the PROM.
RBob.
Old Mar 6, 2011 | 11:29 AM
Red 87 GTA's Avatar
having troble understanding the instructions it says jump a and b terminals in the aldl what is that? then remove the iac
Old Mar 8, 2011 | 11:52 AM
dualdj1's Avatar
Car: 98 Chevy Cavalier
ALDL is the diagnostics port inside the vehicle. You also have to unplug the connector for the IAC on the throttle body to get idle set properly.
Old Mar 8, 2011 | 04:26 PM
Red 87 GTA's Avatar
i know what the aldl is but which terminals do i jump?
Old Mar 8, 2011 | 04:30 PM
dualdj1's Avatar
http://0.tqn.com/d/autorepair/1/0/o/F/42140733.gif
Zell1luk
Sep 29, 2015 10:36 AM
