TBI - ECM and VATS - where is the input
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
We're putting together a daily driver 1991 Camaro RS 305 TBI. I have a used replacement 8746 ECM (car did not have the original ECM when purchased).
Currently, car will crank (starter was probably overridden due to old remote starter - now removed) but giving 53 Security code (+ security light on, no fuel from injectors). Tried the resistor pack as the wires inside the column aren't reading the pellet. Still getting the code. (This was all with a mechanic-friend's help).
BTW, It has a new fuel pump, relay, filter, and lines.
We're thinking that the VATS module isn't sending the signal or the ECM is looking for something else. Just received my VATS bypass module today, but it shows 2 different pin-outs for the TBI. I found a schematic bor the 89-92 ECM but pin B6 on the diagram is "not used".
How do I know which pin is the correct one to connect the signal to (and I don't need to know *why* I should just fix the VATS or whatever, the car's not really THAT nice to worry about fixing it).
Re: TBI - ECM and VATS - where is the input
I guessed (based on the schematic I had) and it worked! Started with a little help from the magic starter fluid. Now it starts on demand.
(It was the Blue wire coming from B6).
One question, if anyone else has used the little green bypass (4-wire), is the security light supposed to stay on now?
Car: check
Engine: check
Transmission: check
Can just take the bulb out of the cluster.
RBob.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
All the threads I have found here and elsewhere have said that the security light will be on all the time.
Billy Decker
Sep 4, 2015 03:46 PM
