FAST ECM connection
Old Mar 19, 2011 | 03:03 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
FAST ECM connection
Hi,
Im at a crossroads here with what to do with my new motor. Im thinking of maybe going carb, but would rather stick with the EFI. Ive replaced the 305 TBI motor, which used a 2-plug 746 ECM. Ive read the guide on repinning TBI to TPI. But! I have a slightly different problem, Im using a FAST ECM instead of a 730 ECM. I do have an adapter which connects the FAST ECM to the existing harness, but was for a different car, and is almost certainly pinned wrong. Any help on using the FAST ECM and doing the conversion would be great.
As a sidenote, Im using a Custom EFI Dart manifold, with a Wilson elbow and throttle body.
In my sig Ive got a procharger, which I am selling to get funds to finish the car.
Old Mar 22, 2011 | 10:43 AM
Ronny's Avatar
Re: FAST ECM connection
I thought a member here made up connectors(Megasquirt) but may be able to help with Fast as well. S10Wildside...
Old Mar 23, 2011 | 06:49 AM
gw082008's Avatar
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
I'm thinking of the same conversion but using a First TPI system on a 383 stroker with Brodix IK200 heads. The cam profile is the issue (Comp 280XFI) may be a bit much for the 730 ECM to easily tune so I'm looking at the Fast XFI system.
Let me know if you come up with any ideas.
Old Mar 31, 2012 | 10:33 AM
primo's Avatar
gw082008, I am doing the samethin, if you run into any info please let me know.
Thanks,
Old Apr 3, 2012 | 07:22 AM
gw082008's Avatar
Axle/Gears: 3:23
I decided to go with Dynamic EFI's EBL system.
I aquired a factory service manual which is a big help.
I repinned the existing wiring harness to match a 730 ECM.
I rewired the fan controls to accept a dual fan setup.
Hope to have it up and running next month.
Old Apr 15, 2012 | 08:24 AM
gw082008's Avatar
Axle/Gears: 3:23
Thanks,
The car is a 92 Firebird convertible. The 305 throttle body engine has been replaced with a 383. Repined the 746 ECM harness to match the 730 ECM from EBL. Added dual fans - removed the VSS buffer and repined both circuts.
I used the factory service manual for wiring and repining instructions.
db057
Apr 28, 2019 07:45 AM
skeltor
Feb 2, 2016 10:37 AM
Lanz06
Sep 14, 2015 07:16 PM
Jlanz55
Sep 8, 2015 11:28 PM
andy74
Sep 3, 2015 08:41 AM
