No 5V at MAP and TPS
Old Mar 28, 2011 | 04:34 PM
TimmyJohn's Avatar
1990 V6 3.1. I am working to get this to run so I can evaluate its condition. I got it where it will idle, somewhat, then it dies, no acceleration or it dies. I am currently T/S and am at a point of checking my MAP and TPS initial voltage. My MAP Sensor show 0.2 volts and the TPS has 0.9 - 1.0 volt. Same voltage is at pin A4 and A5 on my 7730 ECM. ECM Fuse is good. Does this mean my ECM is fried? If not where can I begin to look for the problem.
Old Mar 29, 2011 | 11:20 AM
EagleMark's Avatar
Re: No 5V at MAP and TPS
Have you checked for any error codes yet?
Old Mar 29, 2011 | 08:28 PM
TimmyJohn's Avatar
No error codes just code 12 w/SES light.
Update. I did some more testing and applied 5 volts to the TPS using a powercord from a 5 Volt Cell Phone. The engine response to this was an immediate engine start when the key was put in the start position/run. I cycled the engine off and on several times and it started imediately every time. I took the 5 volts cell phone cord off of the TPS and the engine would just crank and crank and not start. Only thing I could figure is the 5volts is generated by the ECM. I tried the cellphone charger on the MAP sensor but could not get it to read voltage other than the 5 volts I appled. Using a vacuum gage and applying a vacuum did not affect 0 volts at the output. I also found the wire connecting to the Sensor were bare and could have shorted it I replaced the MAP sensor because it should have had an output voltage and that voltage should have been affected by the vacuum. I also replaced the ECM assuming the MAP burned that part of the ECM. Turned the key and it immediately started and running great. No SES light.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
