Strange values in Tunerpro Datalog
Old May 7, 2011 | 07:56 AM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi all!
I hope you can help me out with that problem.
As some of you may have read, I'm trying to get my new engine running properly. So far I just had about 210rwhp , maybe that was just caused by a weak spark + false spark plugs ( used NGK Tr55 before, now the ones recommended by AFR).
Now to my problem:
When I do some datalogging, some datalog samples are way off, looks like the tourette syndrome
I attached my latest log. Not running very good, especially without transmission bolted on.
Did someone had the same problems?
I'm using TunerPro v5 with the ALDLxtreme USB cable from Moates.
File Type: zip
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
