Quick ECM question
Old May 15, 2011 | 02:15 AM
DoubleV's Avatar
Quick ECM question
Does a CCC ECM retard your timing advance if the engine temps are hot...let's say around 200+?
I ask because my engine runs a bit hotter than it should ( am working on correcting that ), and it it noticably down on power when the engine temps are high. Runs much stronger when engine temps are low. I understand this is fairly normal, but seems a bit too extreme in my case.
Old May 15, 2011 | 11:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Quick ECM question
Most likely yes. Would need to look at the particular calibration to see by how much. But in general GM cals do reduce the spark timing at higher engine temperatures.
RBob.
Old May 16, 2011 | 03:41 PM
DoubleV's Avatar
OK, thanks.
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
