grounds for ecm
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 limited slip
grounds for ecm
when i pulled my ecm out of my dash i found a blue wire not attached to either the ecm or a ground point or anything, the blue wire is coming out of the main wire harness and has a metal loop crimped on the end like the ones found on a ground wire attachment point. has anyone ever seen this before or know whee it goes or if it is supposed to be disconnected. i looked around and nothing jumps out as an obvious attachment point.
i just replaced my ecm and the car still does not read codes like it is supposed to and others have thought it might be a bad ground for the ecm....could i add a new ground wire from one of the sheet metal screws holding the metal box of the ecm together to the metal post behind the kick panel?
Car: check
Engine: check
Transmission: check
Re: grounds for ecm
Don't ground the ECM case locally. The ECM case is grounded via the wires that runt ot he engine block. By adding a local ground, ground loops are created. IOW, other devices will be using the ECM ground wires for their use, not the ECMs use.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
