computer question
Old Jul 18, 2011 | 11:52 AM
demon79's Avatar
Car: 1983 firebird
Engine: 350 lt-1 crate motor
Transmission: borg warner t-5
Axle/Gears: stock 3.27 posi rear disk
computer question
can i use the computer from a car with the vats system in a car that doesn't have the vats?
Old Jul 19, 2011 | 03:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: computer question
It depends. If you use the PROM/MEMCAL from the non-VATs car ECM in the VATs car ECM, it will work. Such as when replacing a bad computer (ECM).
If doing a swap and using the original VATs equipped ECM, no, the injectors won't fire or will stop firing after a few seconds.
RBob.
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
