1990 IROC OBDI or OBDII?
Old Jul 18, 2011 | 02:17 PM
VEGASIROC's Avatar
Transmission: Manual
Hi,
I have a 1990 IROC 305/Manual Trans. Is it a OBDI or OBDII? How can I tell? Also, can you recommend a decent reader. I would like to buy from ebay or harbor freight under $100
Old Jul 18, 2011 | 02:22 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: 1990 IROC OBDI or OBDII?
obd1
Old Jul 18, 2011 | 03:28 PM
AmorgetRS's Avatar
For a reader, a paper clip is about as good as anything. Nearly free.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Jul 19, 2011 | 01:07 PM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
OBD I Systems are in vehicles up to 95. 96 and newer vehicles are OBD II. You should be looking at a OBD I system unless the car has had been changed over to OBD II. Diagnostic Ports are also a easy way to identify which one you has as well. OBD I is more rectangled while the OBD II connector is wider at the top vs. the bottom.
As was mentioned before OBD I tester is about the cheapest tool out there (Paper Clip)
Old Feb 2, 2025 | 03:13 AM
AxP-FR's Avatar
J'ai une pontiac firebird 1990 v6 3.1L , avec un connecteur OBD1. Avez vous une référence d'outils de diagnostique OBD1 compatible avec ma voiture à un tarif raisonnable? Svp
Frozer!!!
Jan 19, 2024 04:55 PM
Djmathis123
Sep 29, 2015 01:36 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
