Can a '86 MAF harness be repinned to work with a '727 computer?
Old Jul 22, 2011 | 04:50 PM
DavidR's Avatar
I found a harness and tpi unit from an '86 Camaro/Automatic trans with an Edelbrock base (manifold). I'm trying to put together a map setup for a '73 car. Just wondered if I could use the harness.
Also, what's the base worth used??
thanks
David
Old Jul 22, 2011 | 05:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Can a '86 MAF harness be repinned to work with a '727 computer?
thanks
David
If this ECM is the '7727 underhood version of the '7730, nope, won't work. The harness connectors are completely different.
RBob.
Old Jul 22, 2011 | 09:37 PM
DavidR's Avatar
Allright, thank you sir. I'll pass on it then. I was hoping I could snag the Edelbrock base in the process if the harness could be made to work...
David
9192camaro
16
Feb 3, 2019 12:21 AM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
perZ
Aug 15, 2015 01:17 PM
matthew911
Aug 12, 2015 09:38 AM
