only code 12?
Old Jul 26, 2011 | 03:34 PM
thumperz's Avatar
only code 12?
so i finally got around to pulling codes out(my check engine light bulb was burned out,had to replace it) all i got was 12,but it still wont start. after i got the steering adjustment done,i started it to bleed the power steering(btw,i have a huge leak,new seals are in order) i bleed it,turned the car off,came back 20 minutes later to test drive,and it wont start.
later tonight at school ill pull specs for all the sensors and test em tomorrow,but in the meantime... anybody have any ideas? was a 305,now 350,thanks to the prevoius owner. could this be a prom issue?
im bored for the next few hours,so ill be searching here til school. thanks guys
Old Jul 26, 2011 | 04:33 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: only code 12?
need more info
Old Jul 26, 2011 | 07:45 PM
thumperz's Avatar
Re: only code 12?
dont know what the problem was,but i got it started,after 5 minutes of wrestling with it. but,now its giving off some lite smoke,so ill spray it down tomorrow as well.
Old Jul 27, 2011 | 08:26 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: only code 12?
code 12 means the ecm is normal no codes it would flash code 12 3 times then any other codes 3 times in sequence of the number if there was something wrong def. another issue with the car
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
