Freescan and 7730
Old Aug 20, 2011 | 06:15 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Freescan and 7730
I'm trying to get my laptop to communicate with my '90 GTA with a home made two-transistor ALDL cable and an old 486 laptop (the only machine I have with a serial port that wants to work properly with my cable). Freescan will connect and show data streaming only if I use the "GM 410B" vehicle and hit the force data button two or three times, none of the other definitions want to work.
The problem is that I get a lot of odd readings. Sitting with the engine off the speedometer on the laptop is pegged and with the engine idling it bounces all over the place. It's showing -40 for the coolant temp, and 170ish for the IAT. RPM looks correct as does the throttle position percentage, but I don't know what I can trust and what I cannot.
Being a 7730 (I think) WinALDL won't work and Freescan is the only other software I've found that will run on this machine. EFILive craps out and there's no point in even trying Tunerpro on a 486.
So that's where I am right now. Any suggestions, or am I stuck trying to find a better laptop that'll run newer software?
Old Aug 20, 2011 | 07:50 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Freescan and 7730
Try TTs Datamaster. http://www.ttspowersystems.com/DataM...ownloads2.html
Old Aug 20, 2011 | 07:52 PM
ninetyone's Avatar
Axle/Gears: 3:42
there is also Moates ecm852. That works with Windows 98.
Old Aug 21, 2011 | 04:57 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Datamaster's system requirements are too high for the ol' 486 and I didn't have any luck with ecm852, it would stay in offline mode. I'll have to try that one again though, I must be missung something...
Old Sep 5, 2011 | 08:53 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
I just tried another laptop with a working serial port and both Freescan and EFILive. Same results with Freescan, some plausible readings and a lot of gibberish, and EFILive wouldn't connect at all. Could it possibly be my cable? I might just bite the bullet and buy a USB cable.
Old Sep 5, 2011 | 09:40 PM
ninetyone's Avatar
Axle/Gears: 3:42
buy another cable and try TTS Datamaster.
Old Sep 5, 2011 | 10:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
took two tried building a cable to get it right and used winaldl just fine.
seems as if you can over heat the parts, I was much quicker at soldering the 2nd time.
BWilcox
Sep 20, 2015 12:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
LBSZ28BLOWN
Jun 12, 2002 03:29 PM
HighHopes85
Jun 8, 2001 05:21 PM
