Acceleration bog with larger injectors
I have an issue where, especially in cool weather, when the engine is not all the way warmed up, I get a terrible bog down on acceleration. The thing just starts sputtering and can barely get going. I have to basically ease really slowly into the throttle and get it gradually up to speed, then it's happy.
This is a 7747 on a 350, mostly stock but I did put cop car injectors on (don't ask me why, I'd take it back now if I could). I read that the AE is not a function of BPW (which I have adjusted), so maybe that's my problem?
I started with an ASDU bin and have adjusted my BPW down to 122. I think I should scale my AE vs. dTPS and AE vs. dMAP tables by a factor related to the flow rate. I've been assuming 55 lbs/hr for normal 5.7 injectors and 65 for cop car injectors so I'd scale by 55/65 = 0.85? Does that sound right? I tried this and didn't notice any big difference, but then I don't have a cool day to work with right now.
Anything else I should worry about with respect to bigger injectors? Thanks.
Car: check
Engine: check
Transmission: check
Re: Acceleration bog with larger injectors
The early stock 5.7l injectors are 61 #/hr. Also need to adjust the proportional gains.
Although the change from 61 #/hr to 65 #/hr isn't all that much.
RBob.
RBob.
Thanks. Yeah if it's 61 to 65, I can't believe it's causing my symptoms - but I did go from 135 to 122 on the BPW to get the BLMs even in the ballpark, so something is up with fueling. The whole story is that I bought a TBI "system" from a company and they accidentally sent me a throttle body and injectors from a 305. We couldn't get it to hardly run until I discovered that the injectors were wrong. I swapped the 305's for cop cars and started over on the bin. Could there be anything else going on, like the fuel pressure being different for a 305 setup?
Car: check
Engine: check
Transmission: check
61 / 65 = 0.94
122 / 135 = 0.90
Fairly close ratios.
Maybe try reducing the MAP & TPS AE PW tables by 8% (multiply by 0.92).
RBob.
122 / 135 = 0.90
RBob.
Car: check
Engine: check
Transmission: check
Code:
;---------------------------------------------- ; PROPORTIONIAL VALUE vs SLO o2 ERROR ; FOR SELECTING BIN VAL TO ADJUST THE INTEGRATOR ; ; TBL = BIN * 1 ;---------------------------------------------- ORG $D4A8 . . . ;---------------------------------------------- ; PROPORTIONIAL GAIN FLOW FACTOR vs AIR FLOW ; ; Used to modify prOp gain count. ; ; TBL = MULT * 256 ;---------------------------------------------- ORG $D4C7 . . .
RBob.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
57, 7747, 8, acceleration, bigger, bogs, cop, engine, gain, gen, injectors, reaccelerates, tps, transmission
