Moates OBD1 CABL1 pinout?
Old Sep 3, 2011 | 04:06 PM
Marc Maro's Avatar
Car: 1991 Camaro Z28
Engine: 5.7 TPI, Dyno Don Headers
Axle/Gears: Eaton Posi - 3.42
Does anyone have the pinout or can upload a close up picture of the RJ45 end of the moates ALDL CABL1?
I lost the original cable to my AutoProm and I'm trying to use the cable from my AutoXray scanner that seems to be the same. I'm sure I can just cut off the end of the autoxray and use another RJ45 end.
Old Sep 5, 2011 | 07:15 AM
EagleMark's Avatar
Re: Moates OBD1 CABL1 pinout?
Just but a new cable! Don't mess up your Scan tool cable. It may work? But why? The replacement cable for AutoProm is probably cheaper than all the other ALDL cables because it's just a cable, the stuff is in the AutoProm.
Old Sep 6, 2011 | 09:10 AM
Marc Maro's Avatar
Mark, understood, but the thing is that I have a spare scanner cable, and from the looks of things moates uses an identifical cable, but modified to fit the RJ45 jack. I just needed a picture of the CABL1 so i can avoid spending the $30 on another cable.
Old Sep 6, 2011 | 09:20 AM
EagleMark's Avatar
Now I see the sense to your madness!
I will take a look at mine this afternoon when I get home and see if I can tell which color wire goes where...
InfernalVortex
Apr 20, 2021 11:31 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
