Would a missing ground cause an ecm failer?
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
I forgot to hook up the set of ground wires that connect to the passenger side cylinder head when replacing the head gaskets. I now lost spark and I was wondering if it is likely that I fried the ecm from running the vehicle with only half of the grounds hooked up?
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Would a missing ground cause an ecm failer?
Not sure about the ECM but I bet you fried something by forcing it to sink more current than it could.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
