OBD II swap?
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
Re: OBD II swap?
what are you wanting to accomplish with OBD II? if its for sequential fuel injection you will have to add a few sensors (crank position sensor and cam position sensor, also rewire your injectors to be able to work indipendantly) to your motor to make it work and best bet to do that is to go with a Mega squirt computer, all the benefits of OBD II programining without the headaches of all the "extra" emissions ****.
Car: check
Engine: check
Transmission: check
Hello, Michael
Aug 20, 2015 03:19 PM
