why am I getting a MAP reference with my MAF TPI system?
Old Oct 15, 2011 | 05:10 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I've been troubleshooting bugs with my 88 GTA. I want to get it tuned and running well (mechanically) and finish the break in before I swap to the 0411 which is ready to go. I still have a slight detonation problem under load, sometimes more than others; I've corrected the problem alot but not yet completely fixed it. When I run my scan tool on it, it gives me a MAP sensor reference, which varies between 2.7 and 2.9 volts, regardless of RPM or load. This is a 1988 car with CSI delete. Curious why this is and if this is anything I need to be concerned about?
Old Nov 26, 2011 | 09:40 AM
formulax4's Avatar
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
Re: why am I getting a MAP reference with my MAF TPI system?
I see this post is a little old but just wanted to try and help.
I have an 87 gta and mine has the same reading,I believe that that setting is a reference for the ecm that maybe calculated off of the tps % when MAF isn't working or car is in limp mode? Not 100% sure of when the ecm would use it.
9192camaro
16
Feb 3, 2019 12:21 AM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
