HELP! can't get into service mode
Old Nov 3, 2011 | 05:21 PM
Trans-Am 435's Avatar
Car: 87' T/A, Formula Hood, Notchback
Engine: stock 5.7 TPI
Transmission: T56, 7.25" triple disc clutch
Axle/Gears: B/W 3.23,Locker adj.sway Herb Adams
Hello,
This is on a 87 Trans Am, 5.7l TPI, 7165 ecm, ARAP 6E
Car ran just nice till yesterday.
now i've got no idle, check engine is allways on, the fan turns on in about one second after ignition is turned on while engine is off, fan stays on.
i'm used to, that the fan stays off. when diagnostic terminals A and B are jumpered, fan turns on, and SES light is flashing.
if i jumper A and B now, nothing hapens, fan is allready on and stays on, SES doesnt start to flash.
any suggestions? open or short circuit? what to check for?
Old Nov 3, 2011 | 05:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: HELP! can't get into service mode
Originally Posted by Trans-Am 435
Hello,
ECM is always in limp mode. Do this:
At key-on, engine-off, observe the SES light. It should turn on briefly, blink off, then turn on solid. Can re-try the test after a minimum of 10 seconds of key-off.
If no blink off, ECM is DEAD; or the MEMCAL is missing/bad/unplugged.
RBob.
Old Nov 3, 2011 | 07:24 PM
Thanks a lot RBob,
it was a bad chip, car is running again :-)
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
327IROC85
Sep 23, 2015 12:11 AM
