EBL-WUD trans indicator
Hi guys- those of you that are running 700r4's. In WUD where it shows which gear you are in, when manually shifted through p/n/r/od/d//2/1 exactly what is indicated here? My memory is that the WUD showed the full range of gears selected manually- currently it shows just p/n or od.
Car: check
Engine: check
Transmission: check
Re: EBL-WUD trans indicator
Since it is showing OD while not moving need to change the high gear switch polarity:
Option Word 2 - Bit 5 - HiGrH
If it is set, un-set it. If currently un-set, the set it.
If using the EBL P4 the parameter is:
Option Word 7 Input Polarity - Bit 2 - 4thIn
When using a stick transmission the ECM uses the ratio of RPM versus MPH to know which gear the transmission is in. Of course need to set up the N/V ratios in the calibration properly.
RBob.
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
