Need some advice
Old Dec 21, 2011 | 06:33 PM
77elky's Avatar
Need some advice
I'm getting ready to install a TPI from an 89 corvette in my 77 El Camino. The elky has a 383 ci engine and 700r4 tranny. I would like to use a OBDII ECM with a EEPROM and program it as 90 corvette using the speed density and then tuning it from there. Can anyone tell if this will work and what issues will I have? Thanks, Steve.
Old Dec 22, 2011 | 02:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need some advice
I am not quite sure of what you are asking. You can't run the SD Corvette code ($8D) in an ODB-II ECM. You can upgrade to an OBD-II ECM along with everything else that goes with it.
See this link at the top of the TPI board:
http://www.thirdgen.org/techboard/tp...-cylinder.html
Could run the $8D code in a '7730 ECM. That is the set up for the '90-'92 TPI f-body cars. Same code ($8D) was used in the '90-'91 Corvettes, except in an under-hood '7727 ECM.
RBob.
Old Dec 22, 2011 | 02:20 PM
77elky's Avatar
Thanks RBob, That was my original plan and I'm thinking it is probably the best way to go without a lot of headaches. I was just wondering if there was any advantage to using a newer style ecm, and it sounds like it may be way too much work for not alot of gain. So I'm getting a 7727 ecm and going that route. Thanks again for the information
Old Dec 22, 2011 | 02:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Not sure what injectors you have but you will need to step up to at least 24#hr. check this out to get you started on the tune.
http://www.dynamicefi.com/EBL_P4_Flash.php
Old Dec 22, 2011 | 04:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Before going with a '7727 ECM, check what that ECM uses for connectors. They are quite different then the '89 Corvette '7165 ECM and the newer SD '7730 ECM.
The only reason to use the '7727 is if it is going to be under the hood.
RBob.
Old Dec 22, 2011 | 04:13 PM
Engine: Lb9
Transmission: M20
the connectors are easy to find at the junk yard.
REGAL (6) 1988-1992
1992 V6-189ci 3.1L F/I Vin T
1991 V6-189ci 3.1L F/I Vin T
1990 V6-189ci 3.1L F/I Vin T
1989 V6-173ci 2.8L F/I Vin W
1989 V6-189ci 3.1L F/I Vin T
1988 V6-173ci 2.8L F/I Vin W
CHEVROLET (11) 1990-1993
CORVETTE (2) 1990-1991
1991 V8-350ci 5.7L F/I Vin 8
1990 V8-350ci 5.7L F/I Vin 8
CORVETTE ZR1 (2) 1990-1991
1991 V8-350ci 5.7L F/I Vin J (ZR1)
1990 V8-350ci 5.7L F/I Vin J (ZR1)
LUMINA (7) 1990-1993
1993 V6-189ci 3.1L F/I Vin T
1992 L4-151ci 2.5L F/I Vin R
1991 L4-151ci 2.5L F/I Vin R
1990 L4-151ci 2.5L F/I Vin R
OLDSMOBILE (8) 1988-1993
CUTLASS SUPREME (8) 1988-1993
1993 V6-189ci 3.1L F/I Vin M
PONTIAC (9) 1988-1993
GRAND PRIX (9) 1988-1993
1990 V6-189ci 3.1L F/I Turbo Vin V
1989 V6-189ci 3.1L F/I Turbo Vin V
Old Dec 22, 2011 | 04:57 PM
77elky's Avatar
wow that's quite a list. Sorry for the interuption, had to pick my wife up at work, someone has to earn a living here, lol. If you'd like to sell your ecm, I'd like to buy it. Maybe I could drive down there either this weekend or next and pick it up. And yes it's gpoing under the hood, not really much room under the dash and I don't have to cut a big hole in the firewall.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
