Distributor & Fuel Pump for HSR?
Old Jan 31, 2012 | 06:33 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Sorry if this is the wrong forum for this...
I'm converting my 1985 Camaro with a 305 TPI setup to a 383 stroker (approximately 400 HP) and Holley Stealth Ram setup. I already purchased the majority of the parts (MAP ECM setup, wiring harness, 30 lb. injectors, etc.) and I have two questions:
1) I assume that the stock fuel pump will not be enough to feed my fuel needs, correct? I know they make a lot of aftermarket pumps, just want to make sure I really need to change before I go to all the trouble of doing so.
2) Is there a preferred distributor (either brand or style) to use with this setup? Can I use the one off my current engine or is it better to upgrade?
Thanks.
Old Jan 31, 2012 | 10:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Distributor & Fuel Pump for HSR?
As for the fuel pump, lots of miles on it? It would be worth replacing it.
The large cap distributor may not clear the Stealth Ram. Maybe check on the TPI board or alternate port intake board to see what others have done.
I only use GM distributors and parts. Can go with a small cap with the remote coil if the large cap doesn't clear the plenum.
RBob.
Old Jan 31, 2012 | 11:40 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
RBob.
Small cap fits well but you still may have to slightly trim the cap where the screw attaches (easily done by hand) if you need to turn it much.
Old Jan 31, 2012 | 12:00 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Do I have to find a distributor that specifically calls for the small cap then?
As for the fuel pump, it has been replaced in the last couple of years - when I bought the car in July, it came with a stack of receipts and one of them was for a replacement fuel pump. Is there a minimum pressure that is required to run the setup I'm going to have, and can I just check the pressure to see if I'm meeting that? Again, I don't mind replacing the pump if necessary but it seems like a lot of work to do "in case".
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
92camaroJoe
Aug 13, 2015 06:07 AM
