87 TPI need advice
Old Feb 21, 2012 | 10:39 AM
dijock94's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
87 TPI need advice
I did a 305 to 350 swap on my camaro. My ecm is original to the 305 now using a 350 hypertech chip. I removed the cat and smog system and am about to removed the egr but heard i need to do a proper delete on the ecm. Im not very good with how this computer system so i need help on what to do
Old Feb 21, 2012 | 01:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 87 TPI need advice
If this is on your '87 car, then relocate the MAT sensor to the air cleaner (make it an IAT). That will disable the EGR system. This occurs because the EGR enable temperature is based on the MAT sensor value.
Making the reading lower by relocating the MAT will prevent the EGR from turning on.
Personally, a stock GM calibration would be better then the hypertech chip.
RBob.
Old Feb 21, 2012 | 02:14 PM
dijock94's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
I was going to buy a 5.7 ECM and then order a prom fro
Tpichips . I tried a stock 87 350 chip in my ecm and the car wouldnt even start.
Old Feb 21, 2012 | 06:33 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
both ecms are the same,its just the prom that is different between 305 and a 350.
Old Feb 21, 2012 | 08:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Two items come to mind: are the injectors the proper 22 #/hr for a 350? And, did the ECM give the 'blink' at key-on, engine-off with the 350 PROM?
RBob.
Old Feb 22, 2012 | 03:47 PM
dijock94's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
The injectors are bosch 22lbs, im not sure what you mean by the "blink" im pretty simple when it comes to this car.
Old Feb 22, 2012 | 06:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The blink verifies that the ECM is running from the PROM. There can still be issues with the ECM, but at least it is running. It is:
At key-on, engine-off, observe the SES/CEL light. It should turn on briefly, blink off, then turn on solid. It is the blink off that is important.
Can repeat the test after a minimum of 10 seconds of key-off.
RBob.
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
