holley commander 950
Old Mar 1, 2012 | 08:50 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
quick story, 92 5 speed 305tpi trans am. 166000 miles when a rod started knocking. putting a built 383 in it. thought i wsa gonna go carb so i CAREFULLY pulled out the harness from the ecu to the c100 plug. changed my mind and bought a holley commander 950 and a single plan efi setup. i have never messed with anything fuel injected before so im still learning. do i use my stock harness and do away with the stock ecm? anything i should know before i start putting this setup in?
Old Mar 1, 2012 | 09:20 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: holley commander 950
The c950 has a different wiring harness than the stock one. I have heard of people rewiring the c950 harness to the factory harness, but it does take time. You would also need to make sure the sensor readings are the same as what the c950 needs to operate.
Old Mar 3, 2012 | 05:27 PM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
ive always heard that the c950 is a direct replacement for the stock one.
Old Mar 3, 2012 | 05:31 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
repin the stock harness to work with the c950.
Did you get a book with the c950? if so it has all the wiring diagrams needed..
Old Mar 4, 2012 | 09:02 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Yeah i've got the book. Haven't really had time to fully read it but I have an electric speedo that runs through the stock ecm. Will it still work with the 950?
Old Mar 4, 2012 | 07:12 PM
efiguy's Avatar
No the 950 will only control engine management, not the gauges etc.
Old Mar 4, 2012 | 11:20 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
You have to swap a few wires around in the connectors but it's not too bad. I wired one to work on a '7730 harness and it took a few hours.
Old Mar 5, 2012 | 08:19 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
u wouldnt happen to know which wires u switched do you?
Old Mar 5, 2012 | 12:53 PM
Engine: 450HP 355
Transmission: TH350
It's been quite a while but it's pretty easy to figure them out. All you need is the diagram for the 950 and the diagram for your car.
One good option is to pick up a spare harness from the junk yard and modify that one just in case you ever need to go back.. or pick up a Holley harness.
Old Mar 5, 2012 | 07:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You have the 950C book. It has everything in there. All diagrams needed. (atleast mine does) you can also find the 7730 harness info on this site.
label everything 1st. Then depin it. and repin it. Like said above start to finish only takes a few hrs.
Old Mar 7, 2012 | 08:03 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
10 4 ill give it a shot. Thanks for the info.
seiplentz
Aug 19, 2019 06:02 PM
RedLeader289
May 28, 2019 01:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
