codes for the 730 ?
Old Mar 5, 2012 | 10:32 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
codes for the 730 ?
I was trying to help a friend out with his tpi car who lives in another state. This is in a 8d mask, He just experienced a code DTC - 53 System voltage too high. He replace his alternator and cleared the codes and no while driving for a while he gets a DTC -88 Internal reset of Electronic Control Module (ECM) and the car dies. I have never seen a code 88 on a 1227730 must be in the firmware? I assume the bad alternator voltage spikes killed the ecm? He also said he has a DTC- 98 - Invalid PCM program and map code 33, To try to help this guy out and I gave him a v6 memcal that I did a cylinder select mod and has to solder in a 27c256 into the memcal. it was working great until he got the code 53.any thoughts on this? I did not think this ecm could produce the codes and maybe its a flash miscount on his part
Old Mar 5, 2012 | 12:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: codes for the 730 ?
Codes 88 & 98 don't exist in $8D. So if they are being blinked out the ECM is likely toast.
The code 53 over voltage is: greater then 17.1 volts for more then 200 milli-seconds. The ECM will shut down the quad drivers on a code 53, but won't itself shut down.
RBob.
Old Mar 5, 2012 | 12:09 PM
Engine: Lb9
Transmission: M20
Thank you rbob, thats what I though but did not know for sure.
Old Mar 6, 2012 | 12:50 AM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
what i assumed as well! after hours of headaches and days of bad luck with my swap . . ..
thanks to both of you!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
