High Idle - 92 z28 5.7
Old Mar 25, 2012 | 05:11 PM
colohusker's Avatar
My son's 92 z28 with the 5.7 wouldn't pass emisions after getting it back together. In researching that issue, there were three injectors that were different than the others, no part numbers on any of them, and 2 of what I think were the original injectors were leaking as well. The engine is a .30 over stock build.
Ordered a set of Accell 150821 injectors, that are supposed to be a direct replacement according to Summit. Got everything back together, and the idle is high at 2500 RPM.
Any suggestions on what to look at?
Old Mar 25, 2012 | 05:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: High Idle - 92 z28 5.7
Vacuum leak.
RBob.
Old Mar 25, 2012 | 06:43 PM
colohusker's Avatar
Thanks, I thought that might be an issue, but haven't been able to hunt it down using starting fluid. Guess I'll tear it down again and try to reseal the plenum and runners.
A related question, does anyone sell a bolt kit for the upper intake/plenum and runners to the manifold?
Old Mar 28, 2012 | 11:20 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Before tearing down, have you done a smoke test yet?
Frozer!!!
Jan 19, 2024 04:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
