ebl noob
Old Apr 3, 2012 | 01:26 AM
raceace18's Avatar
Car: 1989 gta
Engine: 5.7 350
Transmission: borg wagner 5speed
Axle/Gears: 327
ebl noob
few noob questions. i have a 89 gta im looking into getting a ebl flash.
but does it come with software? or do i have to get a additional soaftware?
and is it woth it. and better than chip burning?
Old Apr 3, 2012 | 07:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ebl noob
The only additional software required is the free version of Tuner Pro. Can grab that directly from Mark's site (www.tunerpro.net).
I think it's worth it (but I'm biased), and it beats chip burning all to heck. ECM is back under the dash where it belongs. Takes but a few seconds to flash in a tune.
You can use either the EBL Flash with the Port Mod, or the EBL P4 Flash. One main difference is in the amount of ECM harness connector re-pinning required. The EBL Flash uses the two stock connectors with a small handful of terminals/wires moved.
The EBL P4 Flash requires a third connector along with nearly all of the terminals/wires moved.
Both require a MAP sensor to be added. Which may be a 1-bar (N/A), 2-bar (15 psi boost), or 3-bar (30 psi boost).
There is currently a short thread on the DIY_PROM board where the EBL is being discussed. Along with a long thread where tuning with it is being discussed.
RBob.
Old Apr 4, 2012 | 01:24 AM
raceace18's Avatar
Car: 1989 gta
Engine: 5.7 350
Axle/Gears: 327
Re: ebl noob
thx rob..
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
