closed loop flag winaldl
Old Apr 4, 2012 | 08:06 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
I don't ever get closed loop flag on winaldl. Am I not in closed loop? Or is this flag checked when you not in closed loop? If that was the case it would be checked upon start up. Hmm... thanks again thirdgen
Old Apr 4, 2012 | 08:19 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: closed loop flag winaldl
Is it giving you the rest of your data properly? You'll need to look it over to see if theres any problems. From what I remember, after the cars been running for its set amount of time, theres only a couple things that will determine if it'll go into closed loop. One is temperature, the temperature that the computer sees, not the gauge. Another is that your o2 sensor needs to send a signal thats not only in the right range, but varying. Mine was failing to go closed loop, I looked in the 02 sensor readouts, the sensor was bad in such a way that it sent out about .45 volts, but barely fluctuated. Maybe yours is bad too.
Old Apr 4, 2012 | 08:29 PM
Engine: 5.7 l98
o2 sensor is new. ... is the box checked when ecm is in closed loop??
Old Apr 11, 2012 | 02:51 PM
Ronny's Avatar
checked when in CL
Do you have headers?
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
