Need Tune Service....
Car: 90 Camaro IROC-Z
Engine: L98 350
Axle/Gears: 3.23 posi
Sorry if this post doesn't go here....don't really know where to put this. Anyway, my car is in need of a good tune/chip burning. I bought this car back in Feb and after tearing it apart replacing stuff, I found out the PO ugraded the head with bigger cams.......and didn't burn a new chip. So as it sits my car runs fine but it has a bit of an idle surge due to the wrong air/fuel mix. I have no idea how to chip burn or even get started.....if anyone knows about tuning and would like to offer services for a fee, PLEASE let me know.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need Tune Service....
you might want too look into dynamic.com efi ebl p4 for the 1227730 ecm. another choice would be moates.net g1 and a burn 2 and use tuner pro to see what going on with the ve or adjust the setting on the Idle RPM Deadband (drive) -Increase from 38 in steps of 5
IAC Param, Idle RPM Deadband (Park/Neutral) - Increased from 38 in steps of 5 to try to correct the surge. You will need too datalog to identify the issue or if its known cam swap a vacuum gauge as well. A good start for you
