Can someone please help me out!!
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
Ok here goes.. I have an 88 Firebird originally 305 TPI 5 speed. I changed it over to 89 350 TPI 5 speed. So I need a custom burned chip to make this work.. Who specializes in third gen chip burning and tuning???
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Can someone please help me out!!
ALOT of people will tell you that doing it yourself is the best way to go and Ive tried doing it myself but found out real fast that Id need a phd in volumetric efficiencies its a really steep learning curve and I dont really have the time to be reading all that stuff. I had really good luck with PCM FOR LESS they got my car up and running first try through although the tune wasnt spot on that didnt concern me its running. Since then Ive ordered up a holley hp efi system 550-601 it has self-tuning abilities Im just waiting for it to arrive so I can start ripping all the old stuff out.
