Can anyone tell me if the bottom of the ECM should look like this...
Old Aug 1, 2012 | 09:50 PM
Y_B_A_FOOL's Avatar
Axle/Gears: 10bolt4life
I had a power wire ark on my 1227165 ecm and I blew out pins A12 and D1. Both pins are ground in. When I plugged the ECM back in after my stupid mistake The injectors just stayed open, got hot, and filled the cylinders with gas... I search a U Pull & Pay and could not find the ECM anywhere
But when I took the ECM apart I found this pile of solder that doesn't look like it belongs there. Can anyone confirm this for me? My friend is very skilled with a soldering iron, I would like to save it if I can.
Posting a picture of another '165 ECM that isn't messed up would be great!
Pics:
Old Aug 1, 2012 | 10:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Can anyone tell me if the bottom of the ECM should look like this...
http://www.exatorq.com/ludis_obd1/1227165schematic.html
Old Aug 1, 2012 | 11:24 PM
Y_B_A_FOOL's Avatar
Thanks, definitely helped.
Old Aug 2, 2012 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The '7165's can be tough to find. Also look for mid to late 80's small pickups with the 4 cylinder engine and the single 1-bbl TBI. Many of those used the '7165 ECM. Will need to use your MEMCAL in it to work.
RBob.
Mark_ZZ3
May 24, 2018 01:02 PM
92firebirdguy
Sep 1, 2016 07:53 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
luvofjah
Sep 26, 2015 08:28 PM
