Tpi superchip prom
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Tpi superchip prom
I have a superchip prom Part #8818-b 305 tpi auto 1988 camaro/firebird........computer 1227165 mass air
Anyone know what it actually does and if it will make a 350 tpi work better even though it says 305.... I would assume it would...
Car: check
Engine: check
Transmission: check
Re: Tpi superchip prom
Can't use it in a 350 unless you use the 305 19#/hr injectors with it. Which is not recommended. Moved from DIY...
RBob.
RBob.
Sanjay
Aug 12, 2015 03:41 PM
