91 rs 305 won't prime when at operating temp.
Old Oct 3, 2012 | 06:02 PM
b. randazzo's Avatar
Car will start when cold but go for drive and turn off even for minute try to start just turns over. Put a couple drops of gas in throttle body starts right up.
Old Oct 4, 2012 | 11:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 91 rs 305 won't prime when at operating temp.
Do you need to crank it a bit before it cold starts? If so then check if the fuel pump turns on at key-on, engine-off. Should run for two seconds then stop. This is done via the ECM and fuel pump relay.
RBob.
Old Oct 6, 2012 | 06:34 PM
beast94's Avatar
Car: 1994 Chevy K1500
Engine: 355ci, TBI with vortec heads
In had a similar issue. Mine wasnt priming at all and would need cranking until the oil pressure reached over 4 psi and the oil pressure switch turned on the fuel pump. When the engine was hot it would take much longer to start. It turned out to be a faulty pickup coil in the distributor.
Old Oct 6, 2012 | 07:59 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
That's interesting; the pickup wasn't sensing the reluctor thingy during crank, but it sure must have once it started. I wonder how that could be. Did your car run ok once it started? Did it run better after fixing it?
Old Oct 6, 2012 | 08:00 PM
beast94's Avatar
It ran, but not amazing. It definatley ran much better after replacement. It started everytime too!
Glowsock
Jul 24, 2025 03:15 PM
Fast355
Dec 2, 2016 06:33 PM
Derick15
Sep 17, 2016 05:28 PM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
