Swapping ECM's 165 to 773
Old Oct 7, 2012 | 08:13 PM
slackett66's Avatar
Im about to drop a '90 350/TPI into my '89 305/TPI.
I bought the 350 engine with the TPI and the 730 ECM without the harness.
My 305 is a currently running 89 TPI.
The 165 ECM has 2 connector ports, the 730 has 3.
Do I have to buy a harness?
Can I repin the existing wires? Are there any adaptors out there that I can plug my two existing connectors into and have 3 to plug into the ECM?
Hope this makes sense.
Im sure someone had installed a '90 or later MAP ECM using a 89 and earlier MAF harness.
Any input appreciated
Old Oct 7, 2012 | 10:30 PM
slackett66's Avatar
Re: Swapping ECM's 165 to 773
Dooohhhh
Meant to say the 7730 ECM.
Old Oct 8, 2012 | 10:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Mike has a write up on doing this here:
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Will need to either re-pin or swap the harness. No adapters that I know of.
RBob.
Old Oct 15, 2012 | 07:13 PM
syntax terror's Avatar
With some re pinning you could run $12p and get rid of the maf. It would be a lot less work. http://delcohacking.net/forums/viewtopic.php?f=27&t=356
Old Oct 15, 2012 | 09:33 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
^^^ I'm with this guy.
I'd sell the '730 and get an NVSRAM board for your '165 ECM, and run 12P. Lots of support, realtime tuning with 1 cable. Not as popular here, but no reason you can't post on delcohacking.net for help.
-- Joe
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
