Lean Cruise Parameters
Old Oct 10, 2012 | 06:26 PM
beast94's Avatar
Car: 1994 Chevy K1500
Engine: 355ci, TBI with vortec heads
Im trying to work out some issues I am having with my AFR. I solved the extremely lean problems in my fuel map. I had to richen up the low MAP areas. Im working on my lean conditions while the ECM is in Lean Cruise mode. Most of the issues are solved, but for some reason the AFR gradually climbs up to the high 16's and low 17's and occationally it will continue to gradually lean its self out to low 18's. It mostly does this on long down hill grades and the 16-17's happen during normal driving. Is there a way I can prevent this? My Hiway AFR is set to a max of 16.5. I am running an EBL flash with TT-1 WB and using TunerPro software. Thanks.
Old Oct 10, 2012 | 09:50 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Lean Cruise Parameters
You can disable lean cruise by raising enable speed to max,
HiWy - Min MPH
You can disable Decel Enlean by going Open loop Decel,
Option word 3 - Bit 5 - OpDcl
You can disable DFCO by raising enable temp to max.
Old Oct 11, 2012 | 10:42 AM
Ronny's Avatar
Is DFCO enabled? If so that is it. Mine goes to 22/1 same circumstance.
Old Oct 11, 2012 | 11:32 AM
beast94's Avatar
I dont want to disable it, but I do need to control the AFR. It doesnt go int DFCO during this either. Its a very gradual increase and I think I have figured out a direction to try. It does it while in MAP areas of below 30 and 60+, so I have been gradually increasing the fuel map in those areas. I am also going to time how long it takes for the increase to get unreasonable and then set a time limit on the LC.
Old Oct 12, 2012 | 09:34 PM
beast94's Avatar
I think I may have found a way to alter it. I changed the DE- TPS% Filter along with some fuel map changes has seemed to help a lot.
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
