Fuel pump relay please help
Old Nov 7, 2012 | 08:19 PM
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
I was trying to fix a corroded wire from the connector to the fuel pump relay and as I was pulling one of the prongs I accidentally made contact with the other prongs and it did a spark, now my Kroc won't start it's a 88 tpi 5.7. Could anyone help me figure heats wrong. Thanks
Old Nov 7, 2012 | 09:34 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Fuel pump relay please help
Probably popped the fuse. Check the one beside the rad on the driver's side.
Old Nov 7, 2012 | 09:43 PM
saldav420's Avatar
Transmission: 700r
What's rad? And I did check all fuses on fuse box and they seem ok! The fuses next to the driver side kick panel?
Old Nov 7, 2012 | 09:51 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Single fuse in holder beside radiator.
Old Nov 8, 2012 | 01:10 AM
saldav420's Avatar
Transmission: 700r
Yup that was it! Thank you very much for your help. Your awesome!!!!
Old Nov 19, 2012 | 05:53 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You happen to know what color the wires are to this fuse holder?
The harness I have, someone went a little crazy with the cutters.
-- Joe
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
