Holley HP and I/O usage
Old Mar 5, 2013 | 12:33 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I just purchased the Holley HP system and I have questions related to what I need to use the 4 I/O pin outs for. One I know will go for TCC but I need a relay I believe, any suggestions on a good relay to choose?
Another one or two will go to the fans as I have a dual fan setup. I could wire them in series to only use one output I guess but I like the dual fan functionality
The 4th is really the big question. I see something in the holley EFI program for A/C control but I am not sure what the factory ECM accounts for regarding the A/C. What is the ECM controlling?
What about evap canister? I know the '730 ECM triggered this before. Can I just leave this hooked up but not functioning? Should I be using one of the I/O's to trigger this as well? Thinking maybe best to delete it and just get a vented cap but not sure what other people have done.
All that have done this swap or to a similar aftermarket system your input is much appreciated.
Old Mar 7, 2013 | 01:33 PM
Cosmik Debris's Avatar
Re: Holley HP and I/O usage
Since no-one has answered yet I'll give a couple a go. Any sturdy, heat resistant, automotive relay will work for the TCC lock-up.
Quite a few cars turn the air-con off when you got to full throttle just for that little bit extra. I think that's about it really.
Old Mar 9, 2013 | 12:00 AM
1992rs/ss's Avatar
Can I damage the A/C compressor if I don't hook this up? The Holley efi software has provision for control, but with only 4 I/O ports I am wondering if this is a good use for one or just say screw it. So does the ecm switch the control relay to a different ground or what?
I found a pico relay kit that works for tcc so just trying to lock down last port
Old Mar 9, 2013 | 04:05 AM
I don't think you will damage the A/C if you don't hook it up, it's just for a few extra HP at full throttle. Usually in auto applications a relay has 12v on one of the low power terminals and is activated by grounding the other.
Old Mar 12, 2013 | 12:08 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Some day i will get my holley hp out of its box and hooked up.
Old Mar 12, 2013 | 12:41 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
The AC hookup is to raise idle during clutch engagement
you have 8 ports to use with the HP unit 4 power control and 4 ground control the powers will send the 12v signal in or out and the 4 ground will send a -12v or complete the ground
any relay will be good too
lunati397's Avatar
Ive got a HP unit that I have installed on a monte carlo and a dominator thats going on my camaro
Old Mar 12, 2013 | 06:30 PM
1992rs/ss's Avatar
So if my car is an Auto, the A/C control is not used?
Old Mar 12, 2013 | 10:56 PM
lunati397's Avatar
it is because it will bump your idle up a couple hundred rpm when the AC is on it should just be a feed that reads off the clutch engage or the ac on switch
Old Mar 15, 2013 | 10:48 AM
64duece's Avatar
Correct...A/C is an input for idle speed bump sensed when clutch is engaged. HP ECUs have only 4 outputs, 2 +12V triggers, 2 ground triggers max of 2A or a relay is required. The other 4 channels are inputs.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
