coil/module
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: coil/module
I don't think that I have ever had an ignition coil go out on me so I can't help there. With the Ignition control modules what I noticed was that the engine would stall or have no spark for a half a second. When they get really bad they will cut out often and not start and then all of the sudden start.
Car: 1991 Z28 Vert
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: coil/module
when you replace the ignition module replace the ignition coil as well. Coils are cheap around 30 to 40 bucks.
