Did I buy the right ecm?
Old May 21, 2013 | 09:32 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
My car is a 1989 Trans Am GTA t5 with a custom vats delete chip, I thought my ecm might be fried because it appeared to be in limp home mode, it would start but was really bogged down and the secondary fan was constantly running. I decided to get a new ecm (this one)
and tried it out and it didn't start, only cranked, which is what it did before the vats delete chip. Is this the correct ecm for this year and transmission? I thought also maybe it could be a faulty prom/chip so I'm looking to buy a new one, is this the correct one I should buy?
if it is then I'll just buy that and get another custom chip with vats delete made for it
Old May 21, 2013 | 09:57 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Did I buy the right ecm?
EM7165 computer is correct.
Secondary fan is on either by A/C pressure switch, the relay, or most likely - the fan switch in the passenger side head is stuck on.
The chip you have listed is wrong, your engine code is "F", not "E".
Old May 21, 2013 | 10:11 PM
Axle/Gears: 3.45
Thanks for the reply, I've read about the fan switch problem and tried to look into it but I can't locate it for the life of me
Old May 21, 2013 | 10:18 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Fan switch is located very close to the dipstick tube, right inbetween spark plug #6 & #8. Single wire going to it. Of course it can only be accessed from underneath.
Old May 21, 2013 | 10:43 PM
Axle/Gears: 3.45
I didn't realize you have to take the exhaust manifolds off to see it I looked on autozone for their proms and saw this one, is this one correct? http://www.autozone.com/autozone/par...3759_481636_0_
F.I. 57 Belair
Aug 23, 2021 01:09 AM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
