92 camaro previous owner wire mess
Old Jun 28, 2013 | 03:27 PM
samseye's Avatar
Car: 1992 chevy camaro
Engine: 305 v8
I have read several threads on wiring to get a general idea of what the previous owner may have been doing before I got the vehicle.
The engine will turn over and will start with poured fuel in throttle body until fuel burned off.
I can hear relay and fuel pump kick on and previous owner said they had put new fuel pump in.
Fuel gauge is pegged past full.
I found the ground wire spliced in and grounded under rear seat.
The original ground from harness is not working because pump doesn't work when reconnected.
My first question is where does the factory harness ground to?
Then I notice what appears to be a Vats bypass under the dash.
Two white wires wrapped in orange just cut connecting to nothing and a purple and white wire with resistors.
Is this right way to do this?
I am thinking it would be best to go back to how everything was originally wired and find the real issues vs. the bypasses the previous owner has done.
Any advice would be appreciated.
Old Jun 29, 2013 | 01:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 92 camaro previous owner wire mess
Ground for the fuel pump, check under the front of the drivers seat.
Second picture is a VATs bypass. The small orange wire with the two small white wires is from the key switch tumbler. If done correctly it lets the ECM know that it is OK to injector fuel, and the starter enable relay to close so that it cranks.
Check the fuel pressure. TBI is 9 - 13 psi, TPI is 42 - 47 psi.
RBob.
Old Aug 12, 2013 | 09:28 AM
Joegroulx's Avatar
Car: 1997 Firebird
Engine: V-6
I have 97 firebird 3.8 V-6. I have no power at the fuel pump. Pump is good, fuel relay clicks. The other relay located on the lower left (drivers side does not click. I was told is was a relay for the injectors. No power to the back, no fuel. If you squirt fuel in the engine it will run and die. Help I out o f good solutions....
Old Aug 31, 2013 | 01:38 AM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
Mine was a mess also and not holding my breath I hope to have the wiring done tomorrow. My solution? Im lucky enough to have a carb and live in a state that doesn't deq vehicles 25 years and older sooooo im ripping it out.
Old Sep 1, 2013 | 06:52 AM
samseye's Avatar
Engine: 305 v8
I wanted to update with what was happening. I could here the relay and pump, but no fuel. Started testing wires and turning key back and forth for juice and then I heard a spray in the tank. Sounded like garden hose in there. Took out the sending unit and found the po had spliced a rubber line from pump to metal line and it had failed. So pump was just spraying fuel in the tank and never making it up the line.
Old Sep 25, 2013 | 12:44 PM
Darren1's Avatar
First thing I would do is make sure you have fuel in the tank. A bad ground to gauge can cause an empty tank to show full??? After pump runs check the line at the Injector rail for gas.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
LittleFranks
Aug 20, 2015 03:55 PM
ZsTransAm
Aug 11, 2015 07:30 PM
