OBDII on a 86 camaro???
Old Aug 15, 2013 | 09:21 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
what would be involved in converting a 86 Camaro to run on a OBDII system?? seems to me it would be a better deal .has anyone done this? what donor parts did you use??
Old Aug 16, 2013 | 12:31 PM
Ronny's Avatar
Re: OBDII on a 86 camaro???
OBD 2 started 1994 but went big in 1996 to 2001. for an engine swap I presume you would use the donor harness. The sensors if purchased seperately would cost a fortune. OBD2 was for better emissions and diagnosis. Not sure why you would want to go that route on an older car unless the engine swap.
EBL is the bettter idea for an 1986. see dynamicefi.com
Old Aug 23, 2013 | 10:32 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Look in the tpi boards. A few of us have. Damn engines run smooth and get better economy. Its 21 pages long from start to finish but most what u need to begin is in first 5 pages. I did it for around $1000 but I converted a truck harness.
Old Sep 30, 2013 | 05:16 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
rusty it aint a big deal, just takes time, and most of the TPI sensors will work
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
