TunerPro RT error codes
Old Oct 6, 2013 | 08:27 AM
elesone's Avatar
I must be slow or something, but I cannot find a way to list the error codes stored in the ecm in TunerPro RT5.0. With WinALDL I just click on the tab "Error Codes" and I can see a check mark next to the stored code.
I read thru a few threads but failed to come up with a solution. I know I can watch the SES flashing the codes with the key on, but man that's intimidating when there's four or more codes.
It's prolly so simple some of you will laugh at me. But hey, smack me in the forehead with the palm of your hand and enlighten me.
Thanks.
Old Oct 6, 2013 | 11:51 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: TunerPro RT error codes
The ADX you are using may not have the codes defined. Usually you will find them under "Item List", which will list everything defined and their current value or state.
Old Oct 6, 2013 | 06:19 PM
elesone's Avatar
Six_Shooter - Thanks for the reply. I'm using 1227730_8D.adx. So what do I click on to verify the "Item List"?
Old Oct 7, 2013 | 10:35 PM
In the tool bar at the top, beside where you click to see the dash view there is an Item List view button.
Old Oct 8, 2013 | 07:14 AM
elesone's Avatar
NOTE: The laptop is NOT hooked up to a ECM, just opened TP with the last three files used. Don't know if that makes a difference. I checked it out and this is what I see.
OK for Code 23, 22, 21, 15, 14, 13, 12.
Is this what you meant? Why don't I see the rest of the codes? I take it this list shows actual result if the laptop was connected.
Thank you.
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
