CanI get a better computer?
Old Oct 29, 2013 | 03:24 PM
Iroccer's Avatar
Car: Irocs and only Irocs
Engine: prefer 350s'
Transmission: corvette 700r4s'
I bought an '87 Iroc with a pretty stout motor that wouldn't run right. I got it cheap enough that I could spend some money on it for a little dyno time and a custom chip. The tuner called today and asked if I wanted to tune the car to the stock computer or would I like to upgrade? Is the there a better computer out there? My motor has a cam cam of unknown specs but not stock ,edelbrock heads, acell intake bigger runners of some make,msd ignition. i don't know the compression and much else about it. but it falls flat on it's face at about 3500 rpms any help would be great. This place has been great to me and my many Irocs
Old Oct 30, 2013 | 09:18 AM
Ronny's Avatar
Re: CanI get a better computer?
dynamicefi.com (port mod)
Old Oct 30, 2013 | 09:00 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Define: "upgrade".
To some people the stock ECM is a better piece of equipment than most aftermarket ECUs.
"Upgrade" is in the eye of the purchaser. Some people look at certain functions of a different ECU to be able to tune in a different way as an "upgrade" while others look at them as a shift sideways or downgrade due to losing other functions.
There's also newer code that will work in your ECM, that some people consider an "upgrade".
Old Oct 30, 2013 | 11:41 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
You can pick up a Holley Commander 950 pretty cheap these days. Easy to convert the harness over and it allows you to tune the car in real time while it is running. I have been running one for 10 years now.
Old Nov 4, 2013 | 08:15 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Like Ronny said, its about your personal preferences. I am a firm proponent of MegaSquirt, I have owned and used all of them but there are a few features that the stock ecm via help through dynamic efi can offer that MegaSquirt cannot, yet.
Old Nov 6, 2013 | 03:01 PM
Ronny's Avatar
Can I get a better computer?
Another question is can I get a better datalogging system along with it that can flash to corrected .bin from a VE Learn into ECU?
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
