tuning ?'s
Old Nov 26, 2013 | 08:47 PM
ssgt usaf's Avatar
tuning ?'s
I'm looking at swapping the TPI to an MR mainly to benefit from higher rpm hp. will the stock ECM work with a chip? how about if I went with a 383 and heads and cam? what ECM's are available as a direct swap?
Old Nov 27, 2013 | 11:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tuning ?'s
Not with a 'chip', but with hands on tuning it will work.
As for which ECMs will work, need year & model of vehicle.
RBob.
Old Nov 27, 2013 | 03:16 PM
ssgt usaf's Avatar
Re: tuning ?'s
Sorry it is a 1990 IROC 5.7 liter
Old Nov 28, 2013 | 10:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tuning ?'s
That car uses the 1227730 ECM, which also goes by some other (newer) service numbers. It is the only direct swap ECM for that vehicle.
RBob.
Old Dec 14, 2013 | 09:17 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: tuning ?'s
Put in the ecm/tuning software in on the TPI before you swap intakes. Learn how it works and all the tuning basics so at swap time you won't be helpless. You need a good foundation and making small changes on a stock engines stock tune file is the best way to start.
Zell1luk
Sep 29, 2015 10:36 AM
