Speed Density proms? (90-92)
Old Dec 23, 2013 | 10:17 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I repinned my L03 harness to work with a 350 TPI that was set up for speed density rather than MAF. The original memcal and prom are attached in such a way that I cannot remove the prom to replace it with my new aftermarket prom... Do I need to have a new prom burned with the chip attached to the memcal?
Old Dec 23, 2013 | 12:27 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Speed Density proms? (90-92)
Use a G1 adapter from Craig:
www.moates.net
RBob.
Old Dec 23, 2013 | 05:19 PM
RyanJB's Avatar
www.moates.net
RBob.
Thanks.
This is irrelevant but does the 2timer he sells allow you to run two chips and change them without dropping the ECM?
Old Dec 23, 2013 | 06:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not two chips, but two BINs in one chip. The wire is used to select which of the two BINs is actually used by the ECM.
RBob.
Old Dec 24, 2013 | 05:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you wanted a dip socket like the D2 soldered into your memcal send me a pm I will be more than willing to assist. I have never seen a aftermarket prom sold bye itself so , hypertech, jets, ads all have used a piggyback like the G1. The g1 fits the 165 case better than the other adapters.
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
Randomtask2
Sep 10, 2015 08:37 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
