?converting degC tables to degF inTP 5
Old Mar 10, 2014 | 08:37 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Cant recall how to change all the tables relating to temperature from degC to degF. I know it is something simple. Using the Super_8dm2 XDF. I do have them all changed in my $6E XDF..........
Thanks!
Old Mar 10, 2014 | 10:22 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ?converting degC tables to degF inTP 5
I haven't found any simple way to do it.
I've had to modify the formulas in each item. I usually create a copy of the original and then modify the copy so that I can still have both measurements.
Old Mar 11, 2014 | 09:02 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
C* = (F*-32) x 5/9, so, F* = C* / .5555 + 32.
Old Mar 11, 2014 | 10:36 AM
Ronny's Avatar
Centigrade is your friend...
Old Mar 11, 2014 | 06:31 PM
Car: 1988 IROC-Z
That is what i was thinking. You can right click on a table, edit parameter XDF info, and get lots of pop-up windows. Every table seems to have different "things" in it to modify. Not all formulas are the same. I had one written down, like F=1.35*X-40.0000, but where do you put it? I know i did this with my $6E XDF, just cant recall how!
Old Mar 11, 2014 | 07:47 PM
Car: 1988 IROC-Z
LOL, I use both in the test lab i work in, but as much as i use it there, i still want degF on my hot rods!
84LsxZ28
May 17, 2020 02:21 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
