a quick question
Old May 21, 2014 | 10:57 AM
racerx520's Avatar
a quick question
hi guys, i'm battling my first start up of my new motor. i had tuned performance write me a chip and i am having a little issue with fuel, i tried getting a hold of him 3 days ago but haven't heard anything. I had initially told him i was going to be using 27lb injectors but got a set of 24lb injectors for free. would this be the reason i am getting way too much fuel in?
Old May 21, 2014 | 11:37 AM
Ronny's Avatar
Re: a quick question
Just the opposite. You need to reset the BPC for the size of injector.
It may be the choke values or cranking fuel values. You could try to reduce both a bit and see how it runs.
I assume speed density. Your VE table may be too high as well. I believe it cranks at 400rpms 100 map at VE table.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
