trying to find out where my ecm was bought
Old Jun 7, 2014 | 08:00 PM
bucs_gators_fan's Avatar
Car: 1982 Camaro converted into an 87
Engine: 5.7 TPI
Transmission: Manual
I think the ecm is bad in my Camaro. I used the hitting it method and got the car to run for a few seconds. it was a reman in it. it has a warrenty sticker on it. I don't know if its still good or not because I have no idea where the ecm was bought at. it was in the car when I bought it. the sticker says 7165 ECM remanufactured made in Canada very bottom of sticker says SL1104. just wondering if anyone might have an idea where it came from. thanks
Old Jun 8, 2014 | 09:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: trying to find out where my ecm was bought
The ECM originated with GM, they are the only company that made them. Being a reman just means that a third party tested it and possibly replaced a part or two.
RBob.
Old Jun 9, 2014 | 08:52 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
If you can see the solder side of the board look for very small circular rings around the soldered legs of the components. That hitting it made it run for a few seconds makes it suspect to vibration cracking of the solder joints and not a bad component. Use a loop or magnifying glass. Reheat any joint that looks suspect. Vibration cracking of solder connections in cars is a leading killer of electronics such as radios and speed controls.
Old Jun 9, 2014 | 09:18 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I agree, and would like to say to use some electronics flux when the joints are reheated.
Old Jun 9, 2014 | 05:18 PM
Engine: 5.7 TPI
RBob.
ok, thanks
Old Jun 9, 2014 | 05:20 PM
Engine: 5.7 TPI
great idea. I will bring it down to the dealership I work at and have the guys check it out. would be interesting to find out what was wrong with it. then if it can be fixed, I can still use it as a spare. thanks
Old Jun 9, 2014 | 05:21 PM
Engine: 5.7 TPI
ok, will do. thanks
specialized
Jun 18, 2022 09:26 AM
86IROC112
Sep 7, 2015 01:37 PM
Jae992
Aug 27, 2015 09:07 AM
johanlindgren
Aug 16, 2015 12:16 AM
