CEL When I floor it
Old Jun 26, 2014 | 10:04 PM
tpastorok's Avatar
CEL When I floor it
1991 Camaro RS 305 TBI
In case it becomes relevant at all the tranny was swapped to a manual from a 1990 camaro by previous owner but everything else is pretty much stock
So my check engine light has been popping on if I really get on it and hit high RPMs, and then it goes off the next time a start the car up and stays off until i repeat the same condition. In addition to the CEL, it seems to run a little bit rougher (stumbles a bit) for the rest of that drive.
I'm still working on repeating it with different variables, but when I was driving home tonight, the car had been sitting a few hours so the engine was pretty much cool and I tried repeating it and wasn't able to get the light to pop up. I'll update when I figure out anything else but I figured I'd throw a post out in case anyone else has had and solved the same problem.
Old Jun 27, 2014 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CEL When I floor it
Forced knock test is failing... Blink out the malfunction codes, if code 43 is present then that is the issue.
RBob.
Old Jun 27, 2014 | 09:59 AM
tpastorok's Avatar
How do you blink off a code?
Old Jun 27, 2014 | 10:58 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
jumper the two terminals in the top right of the ALDL connector,turn key to run(don't start engine) your SES light will blink off codes
it flashes each code three times, the first code should be 12
flash.....flash flash
then it will flash other codes, in example code 22(low tps voltage)
flash flash........flash flash
it will keep flashing new codes until it runs out of codes to give you, then it goes back to flashing code 12 over and over again
Old Jun 27, 2014 | 01:25 PM
tpastorok's Avatar
The only problem is that I won't get the light anymore after i turn the car off, it only pops on when i floor it so if i were to go home and shut it off and turn the key to run i wouldn't get the light anymore.
Old Jun 27, 2014 | 05:50 PM
Caveman305's Avatar
Engine: L03, LB9
Codes get stored, as long as you don't disconnect the battery you should be able to flash any trouble codes the ECM has stored
Once you are done reading the codes you should disconnect the battery for 5 minutes to clear the codes
92camaro350cci
Oct 14, 2015 09:29 AM
LC2 TECH
Oct 13, 2015 11:53 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
