need advice on ecms...
Old Aug 14, 2014 | 07:00 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I have found my computer to be bad. I took the casing off and found the problem to be a small silver "box" that is either shorting out internally or has a bad connection somewhere, just the slightest touch will make it act up.
In the event this is not repairable, my questions are as follows:
Other than f bodies, what cars/trucks share the same ecm as my specific car? It is an 88 Camaro with the 350 tpi (auto).
Mine has "88 s10 2.5l" written on the casing, and I can't remember for sure but I'm nearly office I already replaced the original with this one I bought used off Ebay. I seem to remember reading somewhere that that exact model s10 computer will work (for whatever reason). it had worked well for years so I would believe that's correct, but can anyone confirm this?
I will try to upload a picture of the box I'm referring to, but it may not work.
Thanks in advance!
Old Aug 14, 2014 | 09:05 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: need advice on ecms...
I just pulled this off rockauto for the compatible computers. Obviously the removable chip inside is different.
BUICK SKYHAWK1986
CADILLAC CIMARRON 1986
CHEVROLET ASTRO (1987 - 1990)
CHEVROLET CAMARO (1986 -1989)
CHEVROLETCAVALIER1986
CHEVROLET CORVETTE(1986 - 1989)
CHEVROLETLLV1991
CHEVROLETS10 BLAZER(1987 - 1988)
CHEVROLETS10 PICKUP(1987 - 1991)
GMCS15 JIMMY(1987 - 1988)
GMCS15 PICKUP(1987 - 1990)
GMC SAFARI(1987 - 1990)
GMCSONOMA1991
OLDSMOBILE FIRENZA1986
PONTIAC FIREBIRD(1986 - 1989)
PONTIAC SUNBIRD 1986
Old Aug 15, 2014 | 09:15 AM
L98_383_Stroker's Avatar
Can you post a picture of the small silver box? It's probably a crystal oscillator for the the microprocessor, but can't be sure without seeing it. They are pretty easy to get from digikey. They will have a frequency printed on them. Check the solder joints. Look on the web for what a bad solder joint looks like. Pressing on crystals will change their characteristics too.
Old Aug 15, 2014 | 11:45 AM
Black88Z's Avatar
That list is great, thank you. I would have never thought to check rock auto honestly. However I guess I'll be answering your answer with another question lol, I see where firebirds are listed there. Yesterday I checked the computer of a same year firebird, only tbi, and it was different of course, the internals looked nothing alike at all. So I think that list is more accurately a list of cars that CAN share the same ecm, but not all models will. How do I know what models will then? Haha it's all very confusing.
I tried to upload it twice and it wouldn't work... I may be able to from my computer later though. I will try to describe it the best I can though. It is the 88 Camaro 5.7 tpi computer. The small silver box I'm referring to is not directly attached to the green surface (motherboard?), instead it is somehow attached to a yellow/faded white plastic price that is maybe 4-6 in long and the plastic piece has three screws holding it to a metal piece where the connectors for the ecu-wiring harness connect. I hope you are able to follow that because I know it's pretty confusing, certainly is hard to describe haha.
Can anyone undoubtedly confirm that an 88 s10 2.5L has the same computer tho? I'm not sure if transmission makes a difference or not tho..
Old Aug 15, 2014 | 12:23 PM
Ronny's Avatar
Yours is a 1227165. Used in 86-89 Y + F 5.0 and 5.7 car. And others....
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
